HELP! Engine wont shut off!
  • Cowboyup
    • Mar 2006
    • 75
    Since I bought my newer boat, I have been having problems with my ignition. A couple of times now, the boat wouldnt shut off when I turned the key back. I went and disconnected both battery terminals, pulled the kill switch, disconnected the ignition switch, and still the engine kept on running. I sat there for about 10 minutes trying everything to shut it off......finally I blipped the ignition key like I wanted to start the engine and the friction between the starter teeth and flywheel was enough to stop the engine. Not my first choice but it shut it off.......The crappy part of the whole situation was after that, I cranked up the engine again and I could shut it off no problem. I started it and shut it off another 8-10 times trying to repeat the problem so I could look into it a little more. I have changed the ignition switch already, so I know thats not the problem. Does it sound like I will be chasing a ghost for a while? Does anbody have wiring diagrams for the starting/shut down wiring in the boat? Its a 94 SN with the Pro Boss 351.
    Has anbody gone through something like this before? Any help, would be greatly appreciated!
    Also, another note : One day about a week ago I pulled the boat out of the garage and began to wash it. I noticed the warning light on the top of the dash and my ignition light on the breaker panel was on. There was no key in the boat, and ofcourse it was not running and the ignition button was not pushed in. My hour meter was ticking away, and all my accesories were powered. When I pulled the wires off of the kill switch, everything shut off and worked like normal.........what gives??????
  • Cowboyup
    • Mar 2006
    • 75
    ttt
    • Bullet
      • Jan 2006
      • 293
      • Somewhere
      • 2016 SAN 210
      sounds like you need a good wiring mechanic----
      next time pull some spark plug wires off
      2008 SANTE 220 (current)
      2004 SANTE 210 (gone)
      1998 BAJA 252(gone)
      1998 MALUBU WAKESETTER LX(gone)
      2000 CARLSON (gone)
      1992 MC MARISTAR 240 (gone)
      1994 GLASTRON 175 (gone)
      • bkhallpass
        • Apr 2005
        • 1407
        • Discovery Bay, CA
        Wish I could help. If the ignition button is on, and the key is on, the hour meter will move, even if the boat is not started. Since yours was doing it without the ignition on, or the key on, I have to assume you've got a crossed wire, or a stripped wire making contact, or something of that nature. Hopefully someone with better knowledge of the wiring can help you diagnose the problem. BKH
        2001 Super Air
        • 83sn2001
          • Mar 2005
          • 151
          • belmont, nc
          Try your starter relay
          • 83sn2001
            • Mar 2005
            • 151
            • belmont, nc
            Never mind that last post. Does the engine have the protec ignition?
            • Cowboyup
              • Mar 2006
              • 75
              yeas it does have the protec ignition
              • 83sn2001
                • Mar 2005
                • 151
                • belmont, nc
                I would start there. That ignition system is prone to problems. Have never had one before but have seen and heard of problems. Call Vince at SKIDIM. He can probably help you out.
                • wakespirit
                  • Aug 2006
                  • 20
                  Hi,
                  Did you managed to solved your trouble ?
                  I just got the similar stuff today with my 1990 "Ski Nautique" and yesterday was working great never add this before...
                  Only thing was that I did not use the boat fro 3 week due to bad condition and heavy rain. Could it be due becasue of humidity and a contact gets stuck ?
                  thnaks for your help
                  serge
