2015 Nautique Sport 200 Tower
  • btouchstone01
    • Aug 2015
    • 56
    • Tallahassee, FL
    I need to remove my tower so that it can be powder coated. Does anyone have any information and/or photos showing how the tower is connected to the top of the gunwale? (Thought I would ask before just pulling parts to investigate)
    Sent from my SAMSUNG-SM-G930A using PLT Nautique mobile app
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    The legs should be through bolted to the gunnels. You will need to gain access to the tower legs as there are nuts on the underside holding the tower in place. I don't have pictures but once you get a look underneath you'll see exactly what needs to be done. You may have to remove the combing pad to see the nuts.
    1989 Sport Nautique
    • wvance
      • Dec 2018
      • 8
      • Charlotte NC
      Need to be careful if you are going to powder coat it.. There are plastic sleeves inside the tower that the tension springs move in and it will melt during the heat process. The towers came from Roswell painted instead of powder coated for this reason. Might want to contact Roswell first
