Must be an age-thing...
Never had an issue until a couple weeks ago, where it would sometimes go up, but not always. Going down; no problem.
Now: no way of getting it up. I can hear it wants to go down further, if it could.
Desperately need it to go up though!
With the rear hatch down, I can't check and fill engine oil. So yeah, the actuator is acting up.
Can't pull the bolt out where the actuator attaches to the deck, as it's pulled too tightly down.
I switched some wires around in the switch, but all that did was change the going-down from one side to the other in there. I'd now like to check the relay, but have no idea which one it is. Anyone happen to know (on a '97 Super Sport)?
Else can I change wires at the actuator/motor? If it would even only go up 1 cm I could pull the pin and open and close it by hand until it's fixed.
Thanks!
Thanks!
