Charging Batteries on a G23
  • Team230
    • Oct 2015
    • 251
    • Cincinnati, OH
    • 2008 Super Air 230 TE
    I tried to put a charger on my battery on a G23 and every time I hit the charge button, the display says FLO. Per the instructions, this suggests the battery is fully charged, but when I put my volt Meter on the battery, I get 5.7V. I also took off all the wires just to make sure there was not something in the circuit causing this.
    Boat is a 2016 with original batteries. Charger is a 40amp black and decker.
    Thoughts?
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Battery is toast. They don't last forever. You can pull them out and take them to an auto parts store. They'll test them again, but at 5.7v, they're goners.
    • shag
      • 2217
      I don't believe I've ever seen a battery get that low.. Wow
      • lucky7t
        • Mar 2011
        • 1306
        • Oklahoma
        • 2015 SANTE
        I’ve seen them short out internally . This looks to be the case. I bet it fails the load test
        Current Correct Craft Boat
        Correct Craft Boats Owned
        • MLA
          • Dec 2009
          • 1312
          • Lake Wylie NC Area
          Try the charger on the other battery or another battery in your car/truck.
          If youve had below freezing temps, replace the battery(s). Not worth even trying to charge and test a battery that @ 5.7V in the middle of winter. Its done for.
          Of course it will. You can not actually load test a battery thats less then fully charged. if you do, you get a false negative. The exception is a modern inductive battery tester. They can test a dead battery, but its not placing an actual load on them like those old style toaster-testers.
          • Wake.BC
            • Jan 2016
            • 423
            • BC, Canada
            Batteries under warranty? Have the dealer get you a new one
            • Team230
              • Oct 2015
              • 251
              • Cincinnati, OH
              I have the boat at the dealer now. Based on all the testing and the feedback here, certainly seems like the batteries are no good.
              Thanks for the feedback.
