Hi, I need to replumb the shower - the PO has the shower cold water feed plumbed on the intake side before the transmission cooler.. As I understand it, the correct location to tee off the cold water feed is on the pressure side of the engine, right after the water pump.
I'm looking for a supplier for the poly Tee fittings needed. Any suggestions?
Cold water T-fitting should go here I believe.
https://i.imgur.com/VFInNrF.jpg
Here's the current location - under the transmission on the line between the through hull pickup and the transmission cooler.
https://i.imgur.com/Lf5hSBB.jpg
