Damaged Upholstery Panel
  • AGGIE00
    • Aug 2017
    • 23
    • Texas
    Had the boat at the local audio company to upgrade the stereo. They had to put the boat in a bay overnight because they couldn’t complete the work in one day, so they had to lower the tower. I had the Bimini folded back, but all the brackets still on. On my boat, you can’t fold the tower all the way down with the brackets on because they catch the side upholstery. I had the work done in December, and just now realized they broke the backer board for the long port side panel. I’m so pissed. Where can I get the parts and what do y’all think this repair will cost?Is there somewhere good around north Houston that could get this done and make it right?
    2010 SANTE 230
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    You may have to buy a new skin, it’s hard to say without seeing pictures, if you could upload some photos of the damage, we could give more accurate advice.
    1989 Sport Nautique
    • AGGIE00
      • Aug 2017
      • 23
      • Texas
      Let’s see if this works.
      • AGGIE00
        • Aug 2017
        • 23
        • Texas
ID:	578382 Click image for larger version
ID:	578383 Click image for larger version
ID:	578381 And again
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          It looks to me like it just pulled the staples out. Take the bolster off the boat and get a better idea of what you're facing.
          -Charles
          • AGGIE00
            • Aug 2017
            • 23
            • Texas
            No, there’s 2 pieces there. What you’re looking at is where it’s broken. The staples are still in the upper piece that broke off.
            2010 SANTE 230
            • AGGIE00
              • Aug 2017
              • 23
              • Texas
              And how in the world do you remove the bolster? I have no idea how they’re secured to the boat.
              2010 SANTE 230
              • charlesml3
                • Jan 2008
                • 2454
                • Lake Gaston, NC
                • 2022 G23
                2010 SANTE 230
                Most likely with these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
                • AGGIE00
                  • Aug 2017
                  • 23
                  • Texas
                  Thanks. I did some prying on the bolster and found that that’s how it’s on there. Is there a way to pry it free without breaking anything else? Seems if I pull too hard on the edges it may crack other places.
                  2010 SANTE 230
                  • GMLIII
                    • May 2013
                    • 2797
                    2010 SANTE 230
                    Here is what I used to remove.
                    https://www.amazon.com/Lisle-35260-P...4PFFDFB6K3419Z
                    • wakejunky
                      • 679
                      • Ca
                      • 2003 SAN
                      I bet that it would glue up just fine. Could give that a try first
                      • scottb7
                        • Aug 2011
                        • 2198
                        • Carson City, Nevada
                        yeah, a bit of glue might be a good call on this one. some gorilla glue - small amount - if it the broken off piece will stay where you want it, or if you can temporarily tape it with some blue tape to hold it pretty tight.
