Converting an '04 SANTE to Seadek flooring in place of carpeting?
  • wakeboardjoe
    • Apr 2011
    • 63
    • Texas
    Hi,
    Buying an '04 and may need to replace the carpet. Has anyone just tried to change out to Seadek instead? Tks
  • brit_hunsicker
    • Oct 2014
    • 482
    • Overbrook, KS
    • 2001 Super Air Nautique
    I dont think they had started to gel coat the floor by 2004. Once you rip carpet up you will find bare fiberglass, resin, and glue. Will take lots of sanding and then self leveling epoxy or some sort of paint to give the SeaDek a good surface to stick to. Keep in mind you will be able to see whatever paint or epoxy you put on the floor around the seams of panels. And there is a good chance your floor panels will have to be remade or at least reshaped. When you remove the carpet they will likely not fit the way you want them to. Plenty of threads on this site showing you the process. I would recommend reading through at least a few of them. It is quite the project. I plan to do this for myself next winter.
    • wakeboardjoe
      • Apr 2011
      • 63
      • Texas
      Thank you!
      • beamons
        • Jun 2017
        • 376
        • Utah
        I just finished doing it on my '98 SN. A bit of a different layout than the SANTE but I think very doable. There were certain things and products that I would do differently but now after doing it I don't believe that it was too hard. One of these days I will post the process and pictures of how I did it.
        • wakejunky
          • 679
          • Ca
          • 2003 SAN
          There are a few of us here that have done that project. It's a bit of work and expense, just to get things tightened up with panels and then gelcoating exposed sections. Well worth the effort and expense, time and the convenience.
          • Rockymtnsurfer
            • Nov 2017
            • 404
            • Steamboat Springs Colorado
            • 2003 210 SANTE
            Prepping the pink fiberglass is the most important.....self leveling gel will still show imperfections.....just a rec
            • beamons
              • Jun 2017
              • 376
              • Utah
              Several coats of this stuff was what worked best for me.
              https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
              • Canuck-Surfer
                • May 2019
                • 181
                • Ontario, Canada
                • 08 Nautique SV211 96 Sport Nautique
                Beamons...
                I am starting the same project on my 96 Sport. I've been looking at this and FGCI Gelcoat Putty.
                1) Did you sand the raw fiberglass before
                2) How many gallons did you use?
                2) Did you gelcoat on top of this or leave it as is?
                Thanks!
                • Rockymtnsurfer
                  • Nov 2017
                  • 404
                  • 2003 210 SANTE
                  https://www.planetnautique.com/vb5/f...toration/page2
                  Look at #19 and some other comments....pretty helpful thread that might answer some of your questions
                  D
                  • Canuck-Surfer
                    • May 2019
                    • 181
                    • Ontario, Canada
                    D
                    Amazing...thanks! Here I am searching for carpet replacement threads and there is a current one under my nose I missed!!!
