Heater Help
  • 03SANTE
    • Sep 2018
    • 166
    • PA
    • 2003 SANTE
    Heater Help
    Looking for advice to get heater working on 03 210. When you push the dash button, no fan kicks on though you can see there is some kind of current draw because the illuminations on the dash dim slightly when you push in the switch. Do I most likely have a bad blower? If so, how hard is it to access behind the board below the dash. Would love to have some warm air while hauling the kids around on chilly days.
    Any insight is appreciated!
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    It isn't hard to access the blower. Most likely access is from the bow. Take off the seat-back cushion right in front of the driver. Then it's just basic troubleshooting. Use a volt meter and make sure you're getting power at the connection. Try spinning the fan by hand.
    -Charles
    • 03SANTE
      • Sep 2018
      • 166
      • PA
      • 2003 SANTE
      Thanks for the tip! My seat backs are the one piece wrap style that goes the whole way around the bow. Haven't removed them yet but that sounds like a plan.
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        OK. That might not be the best way. I'm not really familiar with the 2003. There might be access from somewhere else that's much easier. Look around and you can figure it out.
        -Charles
