I'm looking to get a spare prop for a 94 sport. I am also trying to figure out what is on my boat right now. On the side of the prop it says OJ 1096 and in the back by the shaft is the number 12322. That is all I can find on the prop for identification. I'd also like to confirm that the shaft is 1 inch. I would like a prop that will handle more weight for wakeboarding. When the boat is weighted down it seems to struggle to get up to speed.
RE: Another prop question
94 Sport should be a ProBoss 5.8 EFI or the carbed 351.
Can't help you with the OJ. But your ACME choices are 654 (Weight added 4 blade), 470 (3 blade) or 422 (Ski 4 blade).
I had a 654 that I can recommended. I needed a prop quick so got the 422 and it seems almost as good but I took a lot of weight out the the boat at the same time since we were going to have family out for the week. For your application I would go 654. But I am interested in hearing more about the 470 from others with a 93-97 Sport Nautique.
It is a 1 inch shaft.
