Rudder cinch and packing nut
  • Lakejackson
    • May 2012
    • 160
    • Lake
    • 2011 Sport 200
    There are two nuts on top of my rudder. I assume the top nut is the packing nut and the bottom nut is supposed to be tight up against the packing nut. Boat is a 2011 sport 200. I was greasing the rudder and noticed that the bottom nut was loose. Can someone confirm it should be tight against the packing nut? Picture attached. thank you.
  • beamons
    • Jun 2017
    • 376
    • Utah
    You are correct. The bottom nut is a locking nut to keep the amount of pressure/tension at the correct amount. You do want a slight leak to keep the shaft lubricated. Only a few drops per minute.
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      Wait, this is the rudder shaft, not the drive shaft. The hose you see there is a remote grease point. I don’t think you want the rudder packing to drip water. The grease is there to do the lubrication.
      • Lakejackson
        • May 2012
        • 160
        • Lake
        • 2011 Sport 200
        Correct Charlesml3. I may have the names for the two nuts incorrect. I just need to know if the bottom nut should be tight against the top but.
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          Yes, it should. The bottom nut is a lock nut to keep the top one from turning on it's own.
