How to remove bow seat back cushion on a 210?
  • ally505
    • Feb 2012
    • 180
    • Somewhere cold and wet
    • 2008 super air nautique 210, zr6.
    Hi, how do I go about removing the bow seat back cushion on an 07+ 210? Is it bolted on or just held with fasteners?
    I need to replace the bow eye so hoping there is access to replace this from behind the seat back?
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    It it’s just Xmas tree tabs. Can’t recall if there are 5 or 6. Pop those loose , and there is a J-Bar hook that locks it next to the fiberglass ...... you’ll need to slide the seat back down and around to get those to disengage
    • ally505
      • Feb 2012
      • 180
      Thanks!
      • bandit628
        • Sep 2016
        • 318
        • Southern Illinois
        • Current-2012 SANTE 210 Past Boats 2000 Mastercraft
        Removing that seat won't help you get to the bow eye. There is no access hole if I remember right. That's how my 2012 210 is.
        You just have to reach up under the bottom seat.
        I replaced my bow eye for a longer one, to work with my ramp n clamp.
        Sent from my SM-G955U using Tapatalk
        • bandit628
          • Sep 2016
          • 318
          • Southern Illinois
          https://www.walmart.com/ip/7PCS-Car-...AaAmxHEALw_wcB
          These can help removing seat backs though.
          • ally505
            • Feb 2012
            • 180
            Thanks guys, I have similar tools so will have a pop at this over the weekend. Fitting a Ramp n clamp too as I don’t like the bump stops and lack of winch on my ramlin trailer.
