1996 supersport engine sputter / rev up. Gas tank removal, pick tube, etc problem?
  • J10
    • Jan 2014
    • 66
    • Toledo, Ohio
    • 1996 Nautique Super Sport
    The motor a couple of times had idled high and then stalled. Or have been going and it speeds up and then down and stalls, and then takes a couple of minutes to start back up.
    I have already replaced fuel filter in canister. Is there a inline fuel filter on my model?? and what do I need to do to check the pick tube for clogging? Should I remove gas tank and clean it out? Any help would be great, thanks
  • JGordon210T
    • Jun 2017
    • 98
    • Green Cove Springs, Florida
    • 2005 Air 216 Team / 1997 Malibu Corvette
    J10, Remove and inspect the fitting/check valve. Most common problem. https://www.nautiqueparts.com/product/check-valve-fuel/ Dont forget the Pn discount
    • J10
      • Jan 2014
      • 66
      • Toledo, Ohio
      Thanks, will check it out
