I own a 2000 Supersport which has a key entry pad instead of an ignition key. I was working on the water pump the other day, then lowered the hatch , turned off the ignition and covered the boat. The next night I tried to enter my code to enable all the electrics and although the LED blinked after every entry, the "on" LED did not/will not come on. So I can't power up any of the electrics or start the motor. The battery is good , there is continuity between the key pad and the "black box", there are no tripped breakers and I know the code being entered is correct. I have pulled the ignition breaker, key pad breaker and the run breaker and tested them also. The horn and fan both work, so I know 12V is reaching the dash. Is it possible I bumped something in the engine compartment that would cause this problem, but still allow me to lower the hatch electrically ? Has anyone run into this problem or can anyone point me in the right direction ?
RE: Keyless Ignition Problem
I don't know what may have happened to cause the problem, but my keypad refused to take my code after having stored the boat for the winter. I ended up calling my local dealer and with the hull id number they were able to give me the factory code for my boat. With that you can re-enter your own code and be back in business. The instructions for entering and clearing the codes is in the manual.
ski206 thanks for the response. I wondered if that might be the case. After spending some time sifting through all the posts, I found another reference to the master code and resetting the password. I talked to the dealer this afternoon and they confirmed that all they need is the hull serial number. So I'll get that tomorrow and let you know how I made out. Thanks again for the suggestion.Thanks
Ken
