Lake Water Temp Inaccurate
  • 03SANTE
    • Sep 2018
    • 166
    • PA
    • 2003 SANTE
    These are the plugs in the gateway. Does anyone know if it is easy to rewire directly or should I just splice and use the old sensor wire?
    Thanks.
    • Skidave
      • May 2005
      • 697
      • York, PA
      SPLICE. You will not easily be able to re-pin.
      As I recall, my temp sensor for my water temp has a connector close to the sensor.
