Hi all,
I'm looking to replace the dual batteries in my 2018 G21, The current batteries go flat if I empty the ballast one time without the engine running, evening after a day riding to charge them up, this means I have to switch the batteries over to combine in order to start the boat. I thought the pumps would run off the accessory battery so you still have the starter battery to get you going?
The current batteries are standard car starting/cranking type, would deep cycle/marine/leisure batteries be better suited? Stereo is the standard system, I only use it sometimes when underway.
Does anyone else fill/ drain their ballast with the engine off?
