Boat Waxing Help
  • jslipher
    • Jul 2013
    • 76
    • Midwest
    Boat Waxing Help
    I've always just waxed my boat by hand each year and followed up with spray wax. I'd like to start using a buffer to speed up the process and be more effective. Do you all use a buffer to wax or still just do by hand? What product(s) do you use? I'd probably get a dewalt buffer if I go that route. Thanks!
  • Schlanseay
    • Oct 2018
    • 9
    • Minnesota
    • ‘08 MB B52 v23
    Same situation here I just used. DA polisher for the first time with the results below. IT IS WELL WORTH IT if you don’t mind doing the work.
    1. Hand wash with power washer
    2. Clay bar: medium cut black clay from Autogeek.net
    3. AIO Compound applies with DA polisher and wool pad
    4. Wax with DA polisher and orange foam pad
    5. Next for me is SiO2 spray
    Autogeek.net
    Griots Garage 6” DA polisher HD
    Lake country 6” foam pads (3)
    7.5” wool pads
    Black Medium cut clay
    Any mist and wipe spray for the clay
    Amazon
    Meguires m6732 Marine /RV One step
    Meguires m6332 Flagship Premium Maine was
    Blackfire SiO2 Spray
    • Bushski
      • May 2018
      • 19
      • Pittsburgh
      • 99 sport Nautique
      I use a Big buffer funny thing this is what i did today. Cutting compound and then polishing compound I've not got to the wax stage yet. Been a couple of years sense I did this. I've got a 20 year old Boat that got a Ton of Hours and never kept in a garage except for winter storage. Big Buffer is really a very hard work out.
      Sent from my SM-G892A using Tapatalk
      • Schlanseay
        • Oct 2018
        • 9
        • Minnesota
        • ‘08 MB B52 v23
        Looks great, what are you using to suspend it?
        • Bushski
          • May 2018
          • 19
          • Pittsburgh
          • 99 sport Nautique
          2 - 3,000 pound come along Hanging from a chain that's around a lvl wood beam I installed.
          • Infinity
            • Sep 2017
            • 730
            • Lake Norman - Denver, NC
            • 2014 SV244 w/ ZR409
            Wow, wish I could suspend my boat like that, my garage ceiling is not strong enough to do what you did and I would love to polish the entire bottom of hull since my boat is black and the bunk carpet has scratched it up even tho I am careful to never power load onto trailer. Trying to figure out how I can get the bottom done all polished up since I bought new bunk boards and composite GatorBak bunk covers so the scratches stop in future.
            Maybe my dealer will let me use his lift sometime for a day so I can get the bottom work done, can always hope!
            To O.P. I use a Makita DA for compound & polish work. Very time consuming but results are incredible if you put in the time and do it right. I have been using Boat Candy products, wool pad for compound and semi-synthetic pad for polishing. On waxing, I do it by hand still even tho I have a pad for that....was thinking about using it this year actually to see how it turns out. I used to use a paste wax (Collonite), but switched last year to Menzerna Power Lock +. It lasts longer, seems to protect better/longer against water spots and lasts quite a bit longer compared to the paste wax. Switched cause I have had excellent results using it on my vehicles.
            • GMLIII
              • May 2013
              • 2795
              Based on Infinity's review , I purchased a 32 oz bottle of Menzerna (Jespar) Power Lock + polymer wax and I'm very pleased with the results. Attached is the link to Amazon.
              https://www.amazon.com/Jescar-Power-...vrand=52336105
              • indo
                • 84
                • Smith mountain lake
                Do you guys wax after you seal ?
                • GMLIII
                  • May 2013
                  • 2795
                  Yes some do and they have used this Jaspar (pictured above) after ceramic coating. I did not ceramic coat my boat but just took my boat to the dealer for some warranty work and to wax my boat with Jaspar. Could not be happier with the results. I have used it the last 3 seasons now.
                  • jtryon
                    • Jun 2011
                    • 239
                    • CT
                    • 2007 Centurion Typhoon
                    Autogeek.net
                    7.5” wool pads
                    Amazon
                    i know this is an old post but sheesh...that second pic i was thinking "why'd he post a pic of his house?" that's how reflective you got the boat, impressive.
                    • CincinnatiCC
                      • Dec 2014
                      • 154
                      • Cincinnati, OH
                      • Current 2016 SN 200 OB Past 2008 SN 206, 1989 SN 2001
                      This may be a dumb question, but did you apply the wax and buff it off with the polisher?
