Rear trunk flush opener? Broke
  • m3the01
    • Aug 2004
    • 60
    Can anyone help me out with a part number. There are three screws that hold this plastic part together. They all have basically stripped through. Stupid design. If there is a newer designed part made out of Stainless steel that would be great.
    Any help would be appreciated, our correct craft dealer here is useless.
    This is for a 2001 Air Nautique 216
    thanks for your help,
    Steven
  • richard
    • Feb 2005
    • 406
    • HK
    RE: Rear trunk flush opener? Broke
    you mean that? I changed mine and it works fine,DIM supply this.
    • m3the01
      • Aug 2004
      • 60
      Sorry but that doesnt look like it,
      Im not even sure what that thing is
      Im thinking of the handle u use to pull up the rear trunk cushion. You rotate it to lock/unlock the trunk area.
      thanks for the quick reponse.
      Steven
      • richard
        • Feb 2005
        • 406
        • HK
        I understand what u said, That opener is weak,It broken some years ago, I can't find substiute so I repair it (use screw to tight it) and use it as handle only, w/out lock funtion now, If some body know where can get,I'll have interest to get too.
