19’ 210 Prop Upgrade??
  • AKJerrod
    • Mar 2019
    • 63
    • Anchorage, Alaska
    • 2019 SAN 210
    My 2019 210 with pro ballast gets here in a week. I’ve already ordered the 600lb bags from wakemakers and 500lbs in lead bags. I’m thinking I’ll run it stock for the first few trips until I get it dialed in before adding the extra weight. Will I need to upgrade the prop after adding extra weight? ACME 1617 is what people are suggesting. Should I just upgrade everything before I even take it out for the first run (Prop and all)? Or wait? Looking for advice from people with the same bot/model and have upgraded the ballast and prop or just the ballast.
    Thx in advance guys
  • jondavis08
    • May 2016
    • 369
    • Battle Creek, MI
    • 2014 SANTE 210 2003 SANTE 210-Sold
    2014 210. 1617 is the best upgrade you can get. I’m riding with 750s in the rear and 550 in the bow. Can only plane off with the 1617
    • XBIGPUN66
      • Oct 2012
      • 456
      • WI
      1617 is a great choice. We use it on our 2014 210
      Ian S
      • AKJerrod
        • Mar 2019
        • 63
        • Anchorage, Alaska
        • 2019 SAN 210
        When you say “plane off” do you mean getting out of the hole better? And does the 1617 make the wave better? I upgraded to 600’s in the rear but haven’t added any bow weight yet (lead is on the way for the bow) Fully loaded the Wake wasn’t good (to much stern weight vs bow weight) but I still pulled a rider out just fine.
        • XBIGPUN66
          • Oct 2012
          • 456
          • WI
          On our 210 we can fill completely pro ballast and bow bag, have 7-8 ppl in boat and it will still pop right out of the hole and plane off up to speed with the 1617. Will not do this with stk prop.
          Ian S
          • mcosub
            • Aug 2016
            • 235
            • Orlando
            • 2020 GS22 2017 SANTE 210
            How is the fuel economy with that prop?
            • XBIGPUN66
              • Oct 2012
              • 456
              • WI
              We don't really pay attention to that. Performance is our main concern. We can surf for 3-4 hrs and use about 1/2 tank or a bit more. I guess that is about 4-5 gph.
              Ian S
              • charlesml3
                • Jan 2008
                • 2454
                • Lake Gaston, NC
                • 2022 G23
                Ha! ha! If you're the least bit concerned about fuel economy, then you need to run as fast and as far as you can from a surf boat!
                -Charles
                • AKJerrod
                  • Mar 2019
                  • 63
                  • Anchorage, Alaska
                  • 2019 SAN 210
                  -Charles
                  Hahahaha I second that. Someone asked me how much fuel I went through this weekend. I said 3 full tanks. They asked me how much that cost. I said idk. I needed the fuel, pretty sure it didn’t matter what it cost lol
                  • ally505
                    • Feb 2012
                    • 180
                    • Somewhere cold and wet
                    • 2008 super air nautique 210, zr6.
                    I put a 1433 on my boat, I was toying going for the 1617 but glad I didn’t, never felt the boat bog down and nice not to have the engine screaming about 30mph.
                    • mcosub
                      • Aug 2016
                      • 235
                      • Orlando
                      My build sheet says mine is a 1579. haven't noticed any issues yet.
                      • swatguy
                        • 1631
                        • Midwest/ Northern IL
                        • 2008 SANTE 210
                        The 1579 is def weak if you’re boarding with full pro ballast or anything above stock. Love my 1617 .
                        1100’s 3/4 full , piggy back in bow , and 300lbs lead stuffed in bow as far forward as possible is wickedly good for wakeboarding . The 1579 wouldn’t get that up. Love my 1617 . I still take the occasional slalom run and rpms are def screaming . But since slalom is maybe 15-20% of my time I keep the 1617 on there .
