Scary event
  • DavidP
    • Mar 2016
    • 22
    • Novi, MI
    • 2011 SANTE 210
    Scary event
    So put the boat in the water this weekend for the first time (2011 210). Dealer serviced and winterized in the fall and I stored it in a heated garage over the winter. Maiden voyage was just a booze cruise around the lake. Half way around a big STOP warning appears and the throttle is locked down to idle. The warning is about overheating. NEVER experienced anything like it. Of course the warning message completely blocks out the temp gauge so I have no idea how hot it became. It was quite dark so really couldn't see anything but you could certainly smell the heat. So I get a guy to tow us back home.
    Come down in the morning and pop the engine cover and discover that the Cat converter on one side is discolored. Holy Sh... So we try to find out if there is a blockage somewhere. Cant find anything. We fire it up and the temp never moves off of 160-165. Take it around the lake and it seems to be running fine. A mechanic comes out to take a look and none of us can find a thing. Has this ever happened to any of you? l
  • Neptune442
    • Jan 2019
    • 255
    • Henderson, MN
    Intake grate temporarily clogged by something?
    • DavidP
      • Mar 2016
      • 22
      • Novi, MI
      • 2011 SANTE 210
      That was my first thought as well but I don't see how that would only impact one bank of cyl. The strainer was loose so I was thinking maybe vapor lock? We opened it and made certain it was seated correctly. Fired it up and it filled immediately, which makes me think the impeller is fine. It really has me baffled.
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        I bet the raw water intake valve is closed.
        -Charles
        • MTRBTR
          • May 2012
          • 485
          • MT
          If the strainer was loose there could have been sucking air in the system which can cause it to overheat.
          2006 SV 211 (Sold)
          97 Sport Nautique (Sold)
          89 PS 190 (Sold)
          75 MFG (Sold)
