Gt 40 not priming fuel pumps
  • Joncrow21
    • Jul 2017
    • 5
    • Corinth, Mississippi
    My 2000 sport nautique with the gt40 motor is not priming the fuel pumps when I try to start it. I did jump the wire from the test on the back of the motor and they come on, but when i try to start it nothing. Any ideas?
  • BobinIL
    • Jun 2010
    • 26
    • E C Illinois
    • 97 Sport Nautique 86 Ski Nautique 2001 82 Ski Nautique 2001
    If your pumps are good it Sounds like a relay.
    • MTRBTR
      • May 2012
      • 485
      • MT
      Check all your battery cable connections. Even the ones on the other end. I had a loose connection in a strange spot one time. Very frustrating
      2006 SV 211 (Sold)
      97 Sport Nautique (Sold)
      89 PS 190 (Sold)
      75 MFG (Sold)
      • peteSki
        • Mar 2005
        • 232
        • Ottawa, On, Canada
        • 2005 Sport Nautique 216 Previous: 1997 Ski Nautique
        Had similar symptoms when I owned a 97 Ski with GT40. A good test is to turn the key from off to run without starting the engine. You should hear the low pressure fuel pump come on for a second or 2. Do this 10-15 times and the pumps should be heard EVERY time. If they fail to come on even once then the relay is not working right. I used to go through a set of relays annually on that boat.... never really knew the real cause, but would just replace them annually and I didn't have very many issues.
