My 07 220 LE has the factory dual battery 1/2/both/off switch in the rear port side locker. (Of course I forgot to take a pic for confirmation of it being a factory switch) A few weeks ago I wanted to install a dual battery charger I had picked up. I found the first battery on the port side but found an empty hole on the other side with no cables sticking out anywhere.
I was under the impression you didn't get the switch unless you had the dual battery option. If not, what's required to add the 2nd battery? A set of cables and a battery box?
Unfortunately, I haven't had time to take anything apart and look behind yet to see what's up.
