I could only get 1 quart of fluid out of the trans. shouldn't I be able to get more out. Capacity is 2 quarts
RE: trans fluid change 06 210
It's pretty hard to get a full 2 quarts out of the tranny mainly due to getting all of it out of the bottom of the pan. I would just replace what you pulled out and call it good. Do NOT, repeat, Do NOT overfill your tranny. You'll have a h*ll of a mess on your hands.
Chris
just checked the trans fluid level. I have 2 lines on my dipstick. I'm assuming that the lower is min and the upper is full. Manuel only shows 1 line, full. Mine level is right at the lower line. should I fill to the upper line, or when it's hot will it read a little higher?
