H6 power derate due to low engine oil pressure.
  • Schwiiing
    • Mar 2008
    • 129
    • Norris Lake, Tn.
    • 2017 SAN G23 H6
    Anyone ever had their H6 throttle down and get a code due to low engine oil pressure stage 1 or 2? I have 124 hrs on engine and was running unloaded at 28 mph for 15 minutes and engine started to throttle down, i pulled it back to neutral and engine quite.... would not restart....cranked but no ignition. wasn’t until next day that it would restart. Then it had a noticeable tic as if injector was stuck. Boat loaded back up and on way to dealer.
  • Schwiiing
    • Mar 2008
    • 129
    • Norris Lake, Tn.
    • 2017 SAN G23 H6
    I checked all fluids and power connections... all is as it should be.
    • wakerider107
      • 271
      • south
      Can you post the full code?
      2012 SANTE 230
      • Schwiiing
        • Mar 2008
        • 129
        • Norris Lake, Tn.
        • 2017 SAN G23 H6
        Code 524 and 520. Both low oil pressure stage 1 and 2. Then code 1325, knock retard at limit.
        PCM says engine is blown and is replacing it! Going to loose half of my boating season..... again. Lost it in the past with a snapped drive shaft.
