Steering assist thruster stripped? Need help please 🤜
  • Coloradog23
    • Oct 2017
    • 15
    • Leadville colorado
    • 15 mastercraft x46
    2018 g23, steering assist has worked flawlessly until yesterday. Wife was pulling me and when I got in the boat, the thruster was much higher pitch and it was not engaging the propeller. Upon inspection out of the water, everything spins freely, but when turned on, you can hear the motor engage, but the propeller does not turn. I assume maybe a stick or debris went through it? No visible prop damage. Anyone know if there is a shear pin in the linkage somewhere? Day one of a weeks vacation of course, oh well, don’t have to have it, just spoils you when you do. Seems like the controller box inside by the engine is very well labeled as “do not open”. Thanks
  • SteeleWake
    • Jun 2015
    • 32
    • Discovery Bay, CA
    • 2021 G23 Paragon
    Short answer is yes there is a sheer pin that breaks if debris to protect motor. Easy fix at dealer and good as new!
    Sent from my SM-T713 using Tapatalk
    • FLKeysSurf
      • Sep 2019
      • 31
      • Key Largo
      • 2019 G25 Coastal (previously Yamaha 242LS, Centurion Typhoon, Mastercraft X30)
      Has anyone tried replacing this shear pin themselves?
      • FLKeysSurf
        • Sep 2019
        • 31
        • Key Largo
        Bump on this one. Dealer just quoted me 16-20 hours to replace this shear pin, which seems absolutely ludicrous. Anyone taken this on themselves?
        • jshack01
          • May 2012
          • 139
          • Louisville, Ky
          • 2020 Super Air Nautique G23 (Gold/Onyx Black) 2017 Super Air Nautique G23 (Indigo Blue/Onyx Black) 2012 230 SANTE (Red/White)
          I know this post is older but I did replace the sheer pin myself. Took about 5 hours in total. I have a 2020 G23 and my unit was located behind the engine on the starboard side. The hardest part is getting the two bolts on (and back on) that hold the unit to the transom. I had to use a 13mm open end wrench and a whole lot of words I'm not proud of. . The difference is their example used torx bolts whereas my unit had regular hex head stainless bolts on it. You'll need a shorter length wrench as everything is in the way.
          I'm pretty mechincally inclined and is only a challenging repair because of the location. The 16-20 hour quote from a dealer sounds a bit high but I'm unfamilar with the 2019's and that configuration. Be sure to disconnect the batteries before you start.
          Here is a link to the video that shows how to replace the pin once you have the unit out.. Link
