Hi. My '04's dash has been coming apart at the screw points, now it's loose. Any advice on how to repair these? :/
Tags: None
No advice on how to repair, but if you have deep pockets, you could always replace it.
https://www.nautiqueparts.com/produc...-206-216-2007/I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I've seen it in here somewhere (but could not find it now after a brief search), someone had done a repair to the instrument console attach points using something like a fiberglass patch kit and getting creative. Patching from behind seemed to work well and created a strong attach point for the screws. I recall the final product looking really nice. I was interested at the time because my panel is a little worn/damaged at the screw points as well. However, I have bigger fish to fry right now.
Don’t know about an 04 but my 95 dash plastic isn’t the kind that can be “welded” with a plastic welder. I tried on a small piece that fell off. For broken screw points, I used epoxy to glue washers and nuts on where the screw holes were and converted over to using bolts instead of screws. About 6 months in that’s working fine.
