2004 Nautique SV211 Bow Hard Tank Drain Pump Location Access
  • yager97
    • Apr 2010
    • 33
    • Ontario, Canada
    • 2004 Nautique SV-211 Team Edition
    Hi all,
    Here’s a situation...brought boat to a dealer to have winterized last year, typically I do it myself and store indoor heated, so I don’t do much to the ballast system. Dealer broke the fill pump trying to winterized, it’s been replaced and is now operational. When I fill the center tank, it drains out of the boat and into the bilge. I have deduced from process of elimination that they likely disconnected drain pump as part of winterization process and the tank is draining out through it. Problem is, I can not locate the pump! Exit ports are all starboard side so I assume pump also located starboard side. Is there an access hatch? Do I need to remove the floor??? Does anyone know? Thanks, here’s a pic of the boat after all this reading can’t not.
    Sent from my iPhone using Tapatalk Pro
  • yager97
    • Apr 2010
    • 33
    • Ontario, Canada
    Nobody knows? DoesnÂ’t have to be same boat IÂ’m sure any boat of this vintage is similarly set up
    • beamons
      • Jun 2017
      • 376
      • Utah
      I can’t remember for sure but I thought the pumps are on the tanks. I think it is either under the floor or through the access door in the ski locker. Both are fairly easy to access.
      • NtsDad
        • Sep 2012
        • 14
        • Columbus, Ohio
        • 2005 SV-211
        fwiw... My SV211 is a 2005 and my pump is just to the rear of the ski locker. Let all of us know what you find.
        • yager97
          • Apr 2010
          • 33
          • Ontario, Canada
          Had to remove floor to access pump. Surprisingly easy to remove floor.
