Tower Nav Light Base Replacement
  • blueroom
    • Mar 2017
    • 615
    • Northwest
    • G23
    I broke our G23 nav light base, again. Surf rope got wrapped around it and we let it rip.
    I replaced the snap in base only last year - Attwood 5580-03. Anyone know who sells these at a decent price? Also, there was a separate website where you could order Attwood stuff direct, but I can't remember the site. Anyone know this?
  • blueroom
    • Mar 2017
    • 615
    • Northwest
    • G23
    I found it. The site for Attwood replacement parts is backtoboating.com
    The Nav light snap in base that mounts to the tower (the part that breaks when you hit your light on something or wrap a rope around it) is 5580-03:
    https://www.backtoboating.com/produc...nt=12957379783
    Unless you destroy the light itself it usually pops off the base and is OK, but the base tends to shatter if it gets side load from a rope or strike. Replace the base and pop the old light back in.
    • GMLIII
      • May 2013
      • 2792
      Wow that is a good price . I paid like $35.00 for that part from my dealer after I raised my boat up too far in my boat lift whereby the cable lifting pipe crushed the light on top of the tower
      • jondavis08
        • May 2016
        • 369
        • Battle Creek, MI
        • 2014 SANTE 210 2003 SANTE 210-Sold
        Hmm wonder if that is the same one as my 2014 210.. snapped mine off for the 2nd time. Both lights work but the base is broke. Would rather not pay the extra money..
        • nyryan2001
          • Mar 2013
          • 1993
          • Lake Anna
          A+ Blueroom. Thanks for the share.
          and they are $65 from Nautique
          2019 G23 450
          2014 G23 550
          2013 G23 450
          2011 Malibu Wakesetter 247
          2007 Yamaha AR210
          • scottb7
            • Aug 2011
            • 2198
            • Carson City, Nevada
            Wow! I think it will fit my 2014 g21 so i bought one...For $15 including delivery, I can take a chance all day long....Thanks again!
            • bongrs46
              • Jul 2019
              • 1
              • IL
              • 2019 G23
              Thanks for posting! Amazon sells the whole assembly for $44 but I was never able to find the base only.
              • jondavis08
                • May 2016
                • 369
                • Battle Creek, MI
                Got my base looks like it’ll work perfectly. Is there away to mount without disconnecting the wires? Didn’t know if the light housing can come apart enough to slide the base through?
                • blueroom
                  • Mar 2017
                  • 615
                  • Northwest
                  • G23
                  That is the one drawback, you do need to cut the wire and re-connect. Pretty quick and easy with some butt splices. The first time I replaced one I had hoped you could cut a slot to slide the wire in, which would be doable, but it would show on the external section of the base. This time I might even just use some removable terminals, so next time I don't have to cut.
                  • morrow
                    • Sep 2019
                    • 68
                    • Iowa
                    • 2020 G21
                    Thanks for posting this!
                    • mcosub
                      • Aug 2016
                      • 235
                      • Orlando
                      • 2020 GS22 2017 SANTE 210
                      how does the clear cover come off? I looked at mine over the weekend and it looked like a couple of bugs found their way in there.
