Best way to reinforce engine dividers
  • Mcochran0008
    • Jun 2019
    • 5
    • Ky
    • 2010 SANTE 230
    2010 SANTE 230. I'm gonna pull the rear factory hard tanks and piggy back system and replace with 1100 fatsacs. I've read that the dividers need to be reinforced. Just wondering how everyone is doing this/what the best way is?
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Wakemakers sells kits just for this. Pre-drilled and the screws are included.
    -Charles
    • homer12
      • Feb 2016
      • 584
      • Indianapolis, IN
      • 2004 SV211 TE
      I made my own from aluminum angle and basis hardware- carriage bolt and wing nut. Very simple to make but lining up the holes with the engine divider panels was a bit tricky. I recommend labeling them with a sharpie for what spot they go in if you them out.
