19’ 210 oil change
  • AKJerrod
    • Mar 2019
    • 63
    • Anchorage, Alaska
    • 2019 SAN 210
    19’ 210 oil change
    I want to do the 75 hour oil change myself. The dealer did the 1st at 25 hours but they are charging $300 each time. Is there any other required maintenance during the oil changes or things I should check? Thanks in advance
  • scttp
    • Sep 2015
    • 93
    • Duluth, GA
    • 2015 G
    Your PCM manual should have a maintenance interval checklist. At 75 hrs it should all be DIY still. My 2015 manual has good instructions for all of it too...
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      You should replace the fuel/water separator filter at the same time.
      https://www.nautiqueparts.com/produc...s-pcm-r077019/
      -Charles
