Have a new impeller but my gauge always sits a tick below 175. I know the Tstat is 160. I’m coming from boats that normally do not run that high.
Tags: None
Mine usually stays right around 170. I don't think that 5 degrees more you're seeing is significant.
-Charles
I agree with charlesml3 in that this is probably normal for your engine. My 6.0 ZR450 stays right at 172 if I remember correctly. (Only time I really make note of the specific degree is when winterizing it and waiting for it to get up to temp...)
SatherG230 I figured it would be normal but I wanted to check. I have noticed some heavy white smoke/vapor at times when surfing. From what I can find it appears this has been a frequent asked question before. It appears more like water vapor and does not smell like oil. Also the two times it was heavy was after a big temperature drop from a storm.
Originally posted by Jbousman88 View Post. Also the two times it was heavy was after a big temperature drop from a storm.
-Charles
Charlesml3 like enough to look like a fog machine? There was a old page on here from Skier12 that was excessive white smoke that was exact same amount as me
Yep. Especially in the Spring and in the Fall. If it's only doing that when the temperatures are cool, it's nothing to worry about. You only start getting concerned when there's white smoke all the time...
-Charles
390 zr6, usually runs around 165, high load for a sustained period it goes up to 173. Due a new impeller soon so will be interesting to see if that changes things. Closed cooling too so as mentioned above the antifreeze may have something to do with it.Last edited by ally505; 08-04-2019, 02:10 AM.
