I have a '94 Sport Nautique with a PCM 5.8 Pro Boss EFI GT-40. Occasionally the engine will not fire at all ... and it seems to be after a long ride or session, after it sits for awhile. It just cranks over without firing. While this is happening, no smell of fuel. I pulled off the spark arrestor and no fuel jetting out of the four TBI fuel injectors. The second it starts to deliver fuel, it usually runs normally for the entire session. Low pressure pump engages on ignition key.
Do you think this (1) a fuel supply problem, (2) a fuel pump (low pressure or high pressure) problem, or (3) a command module problem?
Two other problems, related or not:
(a) The engine seems to run hotter than past seasons. I replaced the impeller with some improvement but still runs over 190 to 200 degrees.
(b) Occassionally experience a lack of power on full throttle starts with dark exhaust.
