Linc 2.0 Ballast timers?
  • jc
    • Jun 2004
    • 221
    • Morinville AB. CAN
    • 2008 Super Air Nautique 230 1997 Ski Nautique
    Any way to adjust the Ballast timing on the Linc 2.0? I am upgrading the ballast size and just want the pumps to run longer, I know it's not difficult to just restart them but I find it hard to believe a dealer cant just reset or adjust the timing.
    Ive done some searching and doesn't sound promising but thought Id check again.
    With everyone adding ballast and with the pro ballast option there must be way to increase the fill / drain time?
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Nope. Even in the dealer's menu the only setting is Pro Ballast Yes/No. There is no way to set the run time.
    • kylant
      • May 2010
      • 538
      • Lake Tahoe
      i have read on FB Nautique page that if you go under dealer settings and enable "quagga filter" that makes the pumps run longer.
      I have read on other boat forums, boats with the filters in place have longer run times
      ?? just what i've heard
      • Samu
        • Feb 2017
        • 45
        • Switzerland
        • 2017 G23
        That would make sense. How can you access dealer settings?
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          What is a "quagga filter?" And how would that make the pumps run longer?
          • scottb7
            • Aug 2011
            • 2198
            • Carson City, Nevada
            https://en.wikipedia.org/wiki/Quagga_mussel
            • kylant
              • May 2010
              • 538
              • Lake Tahoe
              i am assuming a "quagga filter" is an inline filter used to prevent quagga mussels from getting into the ballast tanks.
              quaggas and zebra mussels are invasive species and wreak havoc on water ways and equipment.
              our lake has mandatory inspections for all boats and decontamination for boats that have come from bodies of water with known infestations. just last week there were 2 boats, 1 from Arizona that had a massive infestation. The boat was decontaminated and still not allowed to launch.
              I bet the filters make the ballast tanks take longer to fill. just a guess
              • estebanw
                • Jul 2019
                • 11
                • Marin county
                • 2018 GS 22
                Here are instructions from pdf that we got from wakemakers with our extra ballast bags to change the run time of the pumps
                Increasing Ballast Pump Time:
                In the main menu go to the SETTINGS tab.
                On the bottom left menu touch SYSTEM.
                Toward the bottom left corner touch DEALER SETTINGS.
                Input the dealer code 9191 and touch SUBMIT. (If the code does not work please contact your local dealer or customer support at Nautique.)
                Find the “Quagga Filter” option and change it from N/A to INSTALLED
