Hour gauge questions??
  • cam05210
    • Nov 2006
    • 74
    • Charlotte, NC
    When I recently bought my 1989 2001, it arrived to me with 293hrs...I've only used it 4 times and my usage consists of riding to a cove, throwing anchor and hanging out. I have done very little "cruising" and am very meticulous about turning off the ignition switch to kill the power and prevent the hours from adding up unnecessarily. Thursday I was out for a little while and the hour gauge was crossing over 298 which took me off guard since I know I haven't used it that long at all...maybe a total run time of 2hrs. Doing some research I read that the hour gauge isn't all that consistent with how long the engine has been actually running, but rather a combination of how long the ignition has been on coupled with the RPM's of the engine. I timed it myself and cruising around 22-25mph, my gauge was about 2:1..meaning in 5mins, the clock went 10, etc. On the previous trip on the water, I did push the motor a bit since I had just done a full tune up and ran it up to 35-40mph for a brief minute which would tell me it added more time to the clock by doing this?
    Anyone have any knowledge about what actually causes this or the RPM threshold that it begins to tick faster? Some were suggesting 1750rpm? So at idle/no wake speed it should be more in line with true time?? A lot of the article discussed how low engine hours are a indication, but not necessarily an exact reading of the usage of the motor. Found this pretty interesting since we generally place more value on a low hour boat but that may not be all that important after all ??
  • Nautiquehunter
    • Jun 2008
    • 2080
    I have never heard of a hour meter doing anything more than recording the time the ignition is on?
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      It doesn't and this has been discussed here several times. If the engine isn't running the hour meter isn't logging hours. Doesn't matter about the ignition being on or anything else.
      -Charles
      • scottb7
        • Aug 2011
        • 2198
        • Carson City, Nevada
        Charles may know how the oem works, but in general some hour meters are ignition, and some are rpm, some are wired thru a pressure switch to try to prevent running hours when boat engine is off. And the the newer boats actually get the engine hours from the engine ecm, which gets reported to the gateway system or the like, thru canbus.
        • Nautiquehunter
          • Jun 2008
          • 2080
          I guess I am getting old . I cant wait until these cloned space ships are older and the least of you problems will be the hour meter?
          • charlesml3
            • Jan 2008
            • 2454
            • Lake Gaston, NC
            • 2022 G23
            Right. I'm not really talking about the boats manufactured in the years before hour meters were standard equipment on Nautiques. That discussion is best served over on correctcraftfan.com. All of the modern hour meters only measure time the engine is actually running. There are various ways for the meters to "know" the engine is running as Scott described.
            -Charles
            • cam05210
              • Nov 2006
              • 74
              • Charlotte, NC
              Either way, I'm obsessed with cutting ignition totally to prevent unnecessary battery drain and prevent accumulating hours and have only actually run the engine for maximum of 1.5 hours and that's generous at best and I've gone from 293 to 299 in 4 or so outings. When I am just riding around, I average around 25mph and have only run it up to 35+ or so a handful of times but for less than a minute each so it tells me either the rpms are increasing the hour speed or I have a broken part.
