Here is the situation....and I have been PM a person on this forum that has been very helpful! Done bothering him
I have not changed the fluids since I got the boat fall of 17 after it was winterized. Had issues last season, none pertained to fluids....so Idiot me never paid attention to them beside checked levels.....but didn't see tranny stick until now!
Also.....knock, knock, knock on wood!!!! the boat has been great all summer thus far! I really hope I didn't just jinx myself!
Decided to go through all fluids etc.
Oil looks good and changed out.
V-Drive....vacuumed all oil out 3 different times and it looks clean and is replaced fresh...looks great. I could tell it was old and slight milky(could be from numerous reasons, so before I freak out, I wanted to start fresh)
Here we are on the transmission. Fluid was BLACK! Looked like oil, and not trans fluid. I was a little concerned to say the least, but didn't want to jump to conclusions. So.....here we are, I read a ton on this sight, manuals, etc and determined this should be PINK trans oil...DEXIII. So yesterday I vacuumed out the oil....once, filled back with trans....twice, filled back with trans, third and fourth etc. after 4 its a slight dark pink. I would run engine for about 25 secs and put in gear forward and reverse, an then turn off. Hopeing it would stir it up a little. I could be totally wrong on this.
Slept on this all night and even had transmission oil change dreams...WTH!
Here I am 7am deciding what to do.
I was thinking this: Hook up my fake lake hose set up first. Get engine running to operating temp (like manual says) Go get more trans fluid, and continue my vac drain fill scenario process again until its pink....pink pink. Obviously turning off engine in between drain and fill.
HELP....Who thinks this is right or wrong, or what have I messed up? Thank you if you can help ahead of time!
D
D
