330 PCM won’t start!
  • Gwojcik7
    • May 2016
    • 25
    • Finger Lakes, NY
    • 2007 Super Air Nautique 220 Team Edition
    I have a 2007 SANTE 220 with a pcm 330. We were cruising at about 15 mph on the lake and it just shut off on us. It will crank all day long but will not turn on. I checked the lanyard, checked it was in neutral and still nothing. New dist cap this spring also. I had it at the local marina but they couldn’t figure it out either. I am hoping to not have to tow it an hour to the nautique dealer but am running out of ideas. Anything else I should try before I make the trip? Thanks
  • ScooterMcgavin
    • 1478
    • 2014 SAN 210 TE
    Just a suggestion here, but have you checked to make sure your getting fuel? Could be a fuel pump issue possibly. I’d check fuel pressure at the rail. Start with the basics and make sure your getting spark and fuel.
    1989 Sport Nautique
    • Gwojcik7
      • May 2016
      • 25
      • Finger Lakes, NY
      Fuel pump is what I was thinking too but marina said I have good pressure at the rail. I’m at a loss
      • Rockymtnsurfer
        • Nov 2017
        • 404
        • Steamboat Springs Colorado
        • 2003 210 SANTE
        Not sure if this helps at all.......Mine wouldn't turn over Saturday. Was checking it out while my kids was pressing start occasionally. On my 2003 SANTE I believe its the Knock Sensor.....bottom of block rear side....or more toward the middle, but I touched the wire while she was staring it. Its started. As we drove I wiggled it a little and boat would start to die and then keep going. Turned out to be a loose wire connection. taped it up and has started NP every time since. Thought it might be worth a try for you. D
