Perfect Pass Servo Set Screw Size
  • sdtricks
    • May 2006
    • 3
    I need to replace the servo on my Perfect Pass. Unfortunately, the set screw on the servo is stripped and not coming out. I think I'm going to have to try and drill it out and replace with a new set screw. Could be a little interesting based on the size of the bolt and the plastic screw knob.
    Anyone have any idea what size the set screw is? Thanks - AJ
  • skiinxs
    • 374
    • St. Louis
    • 2019 Ski Nautique 6.2 arriving soon
    RE: Perfect Pass Servo Set Screw Size
    If you are replacing the servo motor, go ahead and get a new cable from PerfectPass at the same time. My experience is that they only last around a year, so it probably is ready to break the string anywan. The cable comes complete with a new plastic know (the string is glued to it), so you will not need to mess with the stripped set screw, since it is on the knob.
    Dave
    16 other Ski Nautiques
    3 MasterCrafts
    18 Ski Supreme's
    1 SlickCraft Squirt Boat
