2019 SAN230 well not start
  • Hurley
    • Nov 2018
    • 22
    • Folsom, CA
    • 2019 SAN 230
    Here's what happens. Turn battery on. Press start once to accept on screen disclaimers/ warnings. Press start again, Linc screen activates. Awareness cam screen on, radio on. Press start again and will not start. Important note: Noticed on screen that temp shows 32 degrees, 0% gas, 0 hrs.
    The problem is intermittent. Clutch is in neutral and emergency safety switch is not activated.
  • Johnny_Rock
    • Dec 2016
    • 216
    • MN
    • 2021 G23 (Previously 2016 G23)
    I learned my lesson to check fuses...
    • Hurley
      • Nov 2018
      • 22
      • Folsom, CA
      • 2019 SAN 230
      Thanks for the reply Johnny_Rock . If a fuse was blown would I still have an intermittent problem or would it only start again once the fuse was replaced?
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        Gas gauge and hour meter will show Zero until the ECU is powered up. Sounds to me like it's not getting the signal to start up.
        • Infinity
          • Sep 2017
          • 730
          • Lake Norman - Denver, NC
          • 2014 SV244 w/ ZR409
          Did you check to be sure all the wires are connected tightly behind it? Maybe one is loose, causing the intermittent issue. Could also be loose wire or ground at the starter, or the neutral safety switch, etc
          • kylant
            • May 2010
            • 538
            • Lake Tahoe
            op:
            seeing you are in Folsom, I bet your boat came from Superior.
            Go see them. They are awesome!
            I'm sure they will get you back on the water shortly
