I have a 2019 and the throttle response is terrible. After putting it in drive there is about 2 inches of dead space or no throttle response. If someone wants a little more drag before taking off while being towed, it takes a few seconds to safely/slowly move the throttle far enough to get the engine to respond. Once it gets there it is fine. Dealer said it is normal. Thanks in advance.
Tags: None
Are you sure you're putting the handle all the way into forward (all the way to the detent) before trying to apply throttle?
If so, 2" of dead travel is certainly not right. That's a warranty item for sure.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
It engages and moves forward right away. No further response (change in speed or rpms) for roughly the next 2 inches.
This is not right for sure and no way to adjust a drive by wire throttle that I am aware of. Instant response is the point of these so 2" of dead space means something is out of wack
No way that's right. Did they actually water test it? I would ask them to take me for a ride on one of their demo boats and see if it's the same. Hard to believe that would be considered normal on an expensive boat like that.
You never said whether you are putting the handle all the way into forward (up to the actual detent). The transmission may engage before that, but the handle has a definite detent when it reaches the forward position. I just measured my Ski Nautique throttle distance to the forward detent (I don't have a G here right now), and it was 4" past the locked neutral location.
If you're really seeing 2" of travel after the forward detent, there is certainly an issue.
Post a running video of what you're seeing, and we'll know if it is normal or not.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Originally posted by bturner View PostNo way that's right. Did they actually water test it? I would ask them to take me for a ride on one of their demo boats and see if it's the same. Hard to believe that would be considered normal on an expensive boat like that.
