“Crunchy” Steering
  • jkallen21
    • Jan 2013
    • 399
    • United States
    • 2006 Super Air 220
    “Crunchy” Steering
    I’m sure the title had made you curious. Let me explain. I have a 06 SANTE with original prop and rudder.
    If you’re at plane, what happens if you take you hands off the wheel for a split second? (I’m not suggesting you lay them in your lap or get up to get a sandwich).
    If I do this, the boat will take a definite left turn that gets more and more drastic the longer I let it. Within 3-4 seconds the wheel will have turned about as far left as it can go. With ballasts full, this is even worse.
    Rudder tuning has a small effect but something seems wrong. Under load, if I actually willingly turn the wheel for a slight left, i can feel something in the wheel that I can only describe as “crunching”. It goes away if I straighten or turn right. You can actually hear and see what I’m talking about in this video I took. The noise you hear is coming from the steering wheel and i can “feel” this noise in the wheel too.
    https://youtu.be/u9Aennn9aqU
    Out of the water, or sitting still, the steering is smooth and easy in both directions.
    Looking for any suggestions.
  • windsurfnut
    • Mar 2018
    • 69
    • Ontario
    • 2002 Ski Nautique
    I've been chasing something similar on my 2002 SKI 196. First, on on the SKI for sure, there is a bias to steer left so there is tension on the steering system to track in the ski course. What I found with mine that at a point were that tension unloaded, I got more of a click and the boat would shimmy.
    It appears the little bit of play in the steering system was causing some unloading of tension at a particular point. After MUCH fussing around, I finally tore the helm apart and kind of pressed all parts back in together, tightening up some of the slop in it.
    Outcome has been positive, however the steering is slightly stiffer now as resistance in the helm has increased. No longer does ghost ride left, but it also has removed the shimmy while maintaining the tension for good course driving.
    Hope this helps
    • bturner
      • Jun 2019
      • 1576
      • MI
      • 2016 200 Sport Nautique
      Yikes, yeah that's not normal. First guess would be a rack, second would be a steering cable that is starting to fray or fail. I've rebuilt the steering for friends on several boats over the years. Unless its a frozen cable I pretty much take an "all or nothing" approach to steering repair and my results have been excellent every time. Depending on your system you'll either have a rotary or rack system. All the ski boats I've worked on so far have been Teleflex rack components. If you have tilt (and almost everyone does) there's a good chance the tilt mechanism is sloppy and worn as well. If so I'd recommend going full in and replacing everything.
      I like using Discount Inboard Marine for these components as they're very knowledgable and will be able to tell you what cable you need and which helm manufacture you have. Most likely you'll have Teleflex, if so this is what I typically replace for a rebuild.....
      Back mount rack - https://www.skidim.com/prodinfo.asp?number=TELSH91610P
      Tilt assembly - https://www.skidim.com/prodinfo.asp?number=6301205
      HPS rack assembly - https://www.skidim.com/prodinfo.asp?number=TELSSC15418 *** This is for illustration purposes only, your actual cable will depend on the length needed.
      This is all bolt on stuff that you can replace yourself with some hand tools and patience. Take pictures as you pull it apart and watch videos on how to install a steering cable on YouTube. I'll typically use a set of bolt cutters to the rack off the cable and use the old steering cable to pull the new cable to the rudder clamp block.Make sure you have a drop cloth down around the helm and anywhere else you're working with the cable at as there is grease in and around all these components. The helm rack and pinion will be especially messy as the grease there will have ground metal from wear in it.
      Doing a job like this typically takes me about 4 hours from start to clean up but the results are really outstanding. You'll be amazed at the difference in the feel and control of the steering after it's been brought back to "like new" condition. Best $500 upgrade you'll do to your boat.
      • jkallen21
        • Jan 2013
        • 399
        • United States
        Thanks @btburner!
        I should have included that I had a “professional” mechanic install a new cable this summer. Prior to that I had a heck of time moving the wheel at all once on plane but the boat had been that way since I bought it so I had no point of reference as this is my first Nautique. Is there something that could have gone wrong in his install to cause this?
        So maybe I need to finish the job and do the rest myself. I’m pretty mechanically inclined and there’s little chance I don’t have the tools.
        If you can help me (again) and tell me what tools I need to take with me, I’ll bring them and all the parts.
        • bturner
          • Jun 2019
          • 1576
          • MI
          The problem with a frozen cable is that it stresses the rack and steering components and that will cause accelerated wear which is part of the reason I like to do to the full replacement. If the guy that did the job was a professional I am curious why he let it go out the door sounding like that or at least didn't make you aware of additional issues.
          As to what could have gone wrong..... It's possible he didn't use the old cable to pull the new cable and routed the cable incorrectly or bought / installed the wrong cable. Personally I'd start by getting the part number off the rack. Instead of just ordering parts online I would call Discount Inboard Marine to get your parts and have them verify that you have the correct cable installed before going any further. If you have the correct cable great, if not I'd replace it too.
          Assuming the cable is the correct one and was indeed replaced correctly (I've seen failures with both) the hardest most time consuming part (or at least the part that can be difficult) of snaking the cable through the hull is done. The helm is, as the Brits say, "a bit fiddly", but again take pictures, take your time and it'll come apart and go back together. Order your parts and read the installation instructions. The instructions will have the sizes for all the sockets you need but I would have the following with me.....
          • Full set of metric and SAE shallow and deep well sockets. Most everything can be removed / installed with these. You'll need a larger socket for the steering wheel bolt under the cap.
          • Full set of open end / box end wrenches. Depending on the instillation some nuts / bolts may be necessary or easier to get with a wrench.
          • Hex key set. To get the cap off the steering wheel.
          • Channel locks and pliers.
          • Set of screw drivers.
          • Rags and drop cloth. Drop cloth or large old towel to throw down so you don't great grease on your interior.
          Basically, bring it all. Take a full tool set as you never know what surrounding components of the boat may need to be removed or shifted to get at something. In reality for this job you'll need a hand full of (3 or 4) sockets to remove rack from the pinion housing, the helm mounting bolts, the tilt mechanism and steering wheel bolt. You'll need the hex keys for the steering cap. The rest of the stuff are tools you should have with you just in case. A good Craftsman 300 piece tool set should have all this.
          When I start this project I like to center the rudder as a reference point and make sure it's centered when I put it back together so I can have the steering wheel centered as well. It's more important when you're replacing the cable as you want the rack centered when the rudder is centered. Having everything centered will make sure you have the same amount of travel in the rudder in both directions. This adjustment is typically done at the clamping block by moving the cable forward or back and would be something I would check before pulling everything apart to see if it's currently installed correctly and after for the same purpose. To do this turn the steering wheel "lock to lock" and count the revolutions as you do so. Divide the number in half and with the steering in lock in either direction rotate the wheel that number. That should be center the rudder and the steering wheel. Now go back to the rudder and see if the rudder is centered. If the cable was replaced correctly the rudder should be centered as well as the steering wheel. If it is you had a professional replacement, if not someone should have some splan'n to do. Or it'll be your turn to do it correctly.
          • jkallen21
            • Jan 2013
            • 399
            • United States
            I called skidim today and they were very helpful. Then I went to pickup the boat from the mechanic and may have gotten lucky. The rudder was leaking a bit last summer. He fixed it in the Fall and also replaced the steering cable. Since that time I’ve had the problems described but also VERY easy steering. Maybe too easy.
            Well, the rudder began leaking again and this time he overhauled the rudder. Well, today the steering was much firmer (but not difficult) and the pull is 100% gone!!
            • bturner
              • Jun 2019
              • 1576
              • MI
              Outstanding! One of my favorite sayings is "I'd rather be lucky than good". Being Good is certainly, well good but that good thing will only take you so far. Now that lucky thing, well that can be a real life changer.
              Glad to hear it all work out for you.
              • peteSki
                • Mar 2005
                • 232
                • Ottawa, On, Canada
                • 2005 Sport Nautique 216 Previous: 1997 Ski Nautique
                Interesting... I had a similar sound out of my helm this past week. In my case it turned out I had about 18 inches of poly rope wrapped around the propeller! Must have created vibrations through the rudder that were felt in the steering wheel when at speed. Removed the rope and it went back to normal.
                Agree with bturner though, as I've also taken the do-all approach on this. I've had 2 Nautiques and in both cases had to do a steering cable as it just wore out, so also did the backmount rack and the tilt mechanism at the same time and had great results.
                In light of my issue, might be time to dive into the tilt and see if the universal joint needs some tightening as I've seen them come loose before and it results in 'slop' or play in the wheel.
                • windsurfnut
                  • Mar 2018
                  • 69
                  • Ontario
                  • 2002 Ski Nautique
                  Regarding the placement of the steering tube in the clamp, is there any particular position it should be in? On my install, I centered the rudder, and placed the steering tube in the clamp in such a position that I have equal distances from full left to full right lock.
                  What I'm finding is that the dead spot is right off center - I can feel the steering system start to "compress" as it loads to right from center under power and then actually "release" as the load comes off center as I go left. Feels springy/bungee like. At the point of release the steering wheel unloads -feels weird and boat goes a bit squirrely
                  @btburner perhaps you have some additional insight? I've played with rudder trim, trimming to the left eases the load on the steering system, but at the cost of tracking. Loading right adds the right load to the steering for good tracking but makes the bind/release much worse.
                  My steering cable is only 1.5 seasons old, it operates smoothly otherwise. I've ordered a new backmont rack to see if that improves.
                  • bturner
                    • Jun 2019
                    • 1576
                    • MI
                    Your installation sounds correct and is installed the same as I have done them.Can you feel any hint of a bind or hear anything what would sound like something is meshing correctly when out of the water? Any bind is going to be amplified when under load. This is the same as when someone will complain of stiff steering, then follow with something to the effect that the steering seems fine when on the trailer. If you're feeling any grinding, sloop or lack of smoothness turning the wheel lock to lock with the boat out f the water you probably have wear on the pinion or possibly a bind between the pinion and the rack. This is another reason I replace them both every time I do a steering cable.The thought process being that if one is bad the other can't be much better.That and I'm already in there so I might as well get it all done while I have it apart.
                    I really haven't done any tuning to the rudder. I leave that to the owner.
                    • windsurfnut
                      • Mar 2018
                      • 69
                      • Ontario
                      • 2002 Ski Nautique
                      My steering turns great under load, just that weird spot where it feels like it loads up and releases.
                      At one point I found the clevis pin to have some play in it. I tightened it and this "clicking" of the steering went away for a while. I've since checked the clevis pin and it does not have any play to it still. If I grab the tiller arm though, and move it, I ever so slightly have some play in it that appears to be coming much further upstream (i.e. rack). SO..I'll try the rack replacement in hopes that it is worn there. Just wanted to make sure that the steering tube/clamp didn't need more specific setup
                      • bturner
                        • Jun 2019
                        • 1576
                        • MI
                        Not that I'm aware but then again I'm by no means any kind of engineer for Teleflex or steering engineer. The way I've done the adjustment is just like you did so there's equal travel in both directions. That's what I've used in all my installations.
