2011 230 LINC Piggyback questions
  • hal2814
    • Jun 2016
    • 541
    • Ft Worth, TX
    Friday I’m picking up a new-to-me 2011 230. It only has factory ballast so I’m already planning to add some aftermarket weight. I have 2 x 800lb bags that should will fit in the rear, a 650lb ski locker bag that I think will work, and the parts to run a piggyback system. I’m concerned about LINC v1 and getting my ballast right. From what I’ve read I can’t adjust the system to make it fill or drain longer. Is there really no way to do that? If not, how do I fill the aftermarket bags? Do I just tell it to fill again after it hits 100%? Do I need to run some sort of bypass to physical switches to get the piggybacks full? This will probably make more sense when I’m in front of the boat but I’d like to make sure there’s nothing else I need so I can do this install without having to go back for additional parts on Friday.
    And FWIW, I’ve done a ground up ballast install on my Super Sport so I understand the plumbing. I also understand the basics the piggyback method of using check valves to fill the soft bag and still prevent the tank from collapsing on drain. It’s just the LINC part of the equation (and timers in general) that are new to me. I’d also like to eventually get rid of the rear hard tanks and run larger bags in the back but for day 1 I’ll run what I have. Are there and LINC-related concerns with getting rid of the tanks? I know on the older systems the ballast gauges would stop working but LINC doesn’t have the same gauges.
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    So the ballast timers will run until the hard-tanks are full and stop there. To fill the bags, you'll need to restart the pumps and run them until they start dumping out of the overflow ports. It's not that bad, really.
    -Charles
    • hal2814
      • Jun 2016
      • 541
      • Ft Worth, TX
      The piggyback install for the rear bags went well. I more or less followed the wakemakers method. Restarting the pumps was easy. I didn’t know the ballast control had its own buttons. I thought that was controlled by the linc screen.
      The front is trickier than I thought it would be. There is no ski locker. There’s a screw down panel where the ski locker normally is. Can I put a bag under there? If not, is there any other in-floor option for weight up front? I just used a tsunami to fill up the bag and stuck it in the walkway yesterday but definitely want a plumbed in solution.
      • hal2814
        • Jun 2016
        • 541
        • Ft Worth, TX
        Looks like it’s a no go for a center locker shaped bag. Under that panel is the hard tank. It’s kind of frustrating how much dead space there is right in the nose. I’m contemplating tossing some lead bags under there but I’m afraid I’ll never get them back out. I guess I’ll piggyback an underseat bow sack in, maybe add some lead under the front seats, and call it a day.
