I have a 2014 Super air nautique g23(recent purchase) and I cannot figure out how to get the linc system to display the feed from the tower camera. I am also unable to find any literature in the manual about syncing the camera with the linc system. Does anyone here know the process for setting this up? Any help would be greatly appreciated.
Tags: None
You have to get into the Dealer Menu and set "Awareness Camera" to "Installed." That should be all you need to do.
-Charles
If this is the same camera that came in the 2013 it’s not an awareness camera and it doesn’t automatically connect with Linc. It’s a camera for recording to a handheld unit made by VIO. The output cord that’s wired to camera comes out in the driver side glove box. The VIO handheld holds a USB card and you can record to it.
You can do a hack where you plug the camera cord into the VIO handheld and then plug the video out of the VIO handheld into the LINC video input. Go to the LINC video screen and it will show up. It’s not elegant and it works nothing like the awareness cam.
