I have a 98 Sport with a Boss GT-40 that has had multiple maintenance symptoms this year. I have replaced the Fuel Filter, the Impeller and Thermostat and hopefully that will take care of that problem. I was lead to another forum by Jeff on why my boat won't start on a few attempts then suddenly it will start up. He mentioned the Starter Relay has been notorious for going bad.
Yesterday, I got the new relay from Skidim and proceeded to replace it. I was certain that I was careful on making sure the correct wire will go back on the bolt on the relay but it was such a tight fit that I may have goofed. Now my boat won't even crank. I have checked my 2 batteries and it shows 14 Volts. The radio won't even power on. I checked to see is I was getting voltage from the positive (red) battery wire that connects to the relay and to the starter and its getting 14 volts. I then decided to put my old relay back on to see if the new one was defected and again nothing. I have attached a diagram and a picture showing how I ran the wires. Can any help? Thanks!
