2004 Excalibur 330 Valve Clearances for Valve Adjustment
  • SCNautique210SAN
    • Mar 2011
    • 194
    • SoCal
    • 13 G23 04 SAN 210TE 92 Sport Nautique
    Hey all. Been trying to find a thread or document online that will show me the valve lash adjustments for my 04 Excalibur 330. Haven’t been able to find anything reliable yet so I figured I’d post. Anyone know offhand or point me to a thread/document?
  • Infinity
    • Sep 2017
    • 730
    • Lake Norman - Denver, NC
    • 2014 SV244 w/ ZR409
    There are owners manuals on this forum located at top of page, maybe its lists what you need in there
    • SCNautique210SAN
      • Mar 2011
      • 194
      • SoCal
      Appreciate the reply. Owners manuals don’t give engine specs. They’re more for general operation and maintenance. It’s not in the owner manual or the engine illustrated parts manual. In cars this would be in like a technical service manual that the techs use but I donno if they have that kind of documentation for boats
      • Infinity
        • Sep 2017
        • 730
        You can try this link to see if they have the manual you need: (click on pic to get the download option)
        https://www.skidim.com/searchprods.a...number=1&val=0
        • MLA
          • Dec 2009
          • 1312
          • Lake Wylie NC Area
          A 2004 engine that does not have hydraulic (self adjusting) lifters? There is no valve adjustment, just the pre-load when tightening the rocker nuts. This can be done with engine running or off.
          • SCNautique210SAN
            • Mar 2011
            • 194
            • SoCal
            MLA you’re 100% correct. Embarrassed about this question now but you did answer it lol. All I’m actually trying to do is find the procedure for adjusting the rockers. Found one here: https://www.centuryperformance.com/v...procedure.html But I swore there were still clearances to check when tightening the rockers. This is just to fix some valvetrain noise. Might also be an exhaust leak but figured I’d check both at the same time.
            • MLA
              • Dec 2009
              • 1312
              Did you just rebuild the engine, either complete or top half? Odd to have valve train noise after the initial setting, unless there is an issue with the cam, lifter(s), oil pressure or rockers.
              If you pull the plug wires one at a time, it will change the sound of an exhaust leak. Valve noise should not change.
              Been a 100 years since ive set a SBC, but running was easiest, but messiest. Back off nut till it clattered, tighten down till noise stops, then turn like 1/4 or 1/2 turn more.
              • SCNautique210SAN
                • Mar 2011
                • 194
                • SoCal
                Nope it wasn’t just rebuilt just heard some ticking. Probably more likely to be an exhaust leak. Haven’t tested an exhaust leak by pulling plug wires thanks for the recommendation I’ll try that first.
