Ballast Leak?
  • btouchstone01
    • Aug 2015
    • 56
    • Tallahassee, FL
    Ballast Leak?
    Recently the belly ballast tank on my 2013 Sport Nautique filling without the pump running. Is there a check valve that should prevent this from happening?
    Sent from my SM-G892A using PLT Nautique mobile app
  • Lakejackson
    • May 2012
    • 160
    • Lake
    • 2011 Sport 200
    There is no check valve on my 2011, and I assume your 2013 is the same. When was the last time you changed the impeller on the ballast pump? A worn or broken impeller can let it fill. Also check the cover for the impeller is installed properly and the o-ring gasket is seated properly.
