Conversion from Linc to gauges
  • mlange
    • 90
    • Oconomowoc, WI
    • 2012 SN 200 Mapple Icon Edition
    Ignoring the money side of this question...
    Anyone know if you can replace Linc with gauges in a 2011. Replacement gauges, keypads, bezels, etc... are all available through NautiqueParts. The question is if this is plug-n-play or if there's a lot more to it than that.
  • hal2814
    • Jun 2016
    • 541
    • Ft Worth, TX
    On a LINC 1 off the top of my head there’s no other way to get oil pressure, temperature, or fuel. Those are probably easy to replace. There’s the zero off controls. I would assume you could interface that into a standalone Zero Off controller. I think the speedometer is driven off the linc system so you’d probably need something for that. There are also things like stereo controls, video input, and GPS map. You’d lose those almost certainly. It’s not plug and play but sensors are sensors. It’s all very likely a matter of wiring. But nobody has done it yet. The worst case I can see is if Zero Off is significantly different from the standalone version and you’d need to do a completely fresh install.
    • mlange
      • 90
      • Oconomowoc, WI
      Thanks for the response. I'd expect ZO to be the least of my problems since there's still a head unit on the 200's on your right. I couldn't care less about GPS or video input. I just want a stock look with gauges rather than the LINC display. Sounds like that may not be easy as I would have hoped.
      • DealsGapCobra
        • May 2010
        • 375
        • Knoxville, TN
        • Ski Nautique 200
        Is your LINC 1 dead?
        • hal2814
          • Jun 2016
          • 541
          • Ft Worth, TX
          I imagine one day there will be a kit when the displays are no longer available. In the meantime, there’s nothing plug and play about it.
          • mlange
            • 90
            • Oconomowoc, WI
            No. Looking at a 2011 and don't want Linc 1.0
