Oem 2014 surf pipe on a 210 team 2003
  • Mathieu Roy
    • Sep 2016
    • 8
    • Montreal quebec canada
    • SANTM 2003
    Hi guys hope you are all doing well. Iam trying to find anything on internet but none semes to have tried it
    does anyone ever put a oem pipe on a og 210
    what could go wrong if i put one ?
    I just made it one install by my super good friendand it semes yo fit well but didnt try it.
  • Luebowski
    • Aug 2017
    • 104
    • CA
    • 2004 SANTE 210
    Really depends on how far it sticks into the water. If too long, I think you would have issues with drag?
    When I installed the FAE on my boat all the measurements were exact and they custom built it based on those numbers.
    • Mathieu Roy
      • Sep 2016
      • 8
      • SANTM 2003
      Perhaps do you have the measurements how far down it’s going from the bottom of the hull
      • Beach-TJ
        • Oct 2010
        • 207
        • Lake Lanier, Ga
        • 2004 SAN 210 TE
        Agree with above, should sit with bottom of tube even with center of prop or an inch or two higher than that.
        Also, is it centered with the prop?
        • Luebowski
          • Aug 2017
          • 104
          • CA
          • 2004 SANTE 210
          The longest part of my FAE sits 5 1/2 inches below the hull. Like TJ said above, a couple of inches above the center of the prop.
