2001 SAN engine access
  • dominator
    • Sep 2018
    • 36
    • Burlingame, CA
    • 2001 Super Air Nautique
    I have v-drive boat with PCM GT40 and it looks like certain parts of the engine won't be easy to access. I was hoping that removing engine/storage walls would be enough to access engine oil filter, fuel filter, and impeller. However, it appears that engine/storage walls expose maybe just half of the engine, the bottom half is still difficult to get to.
    I hope I won't have to remove what's under the storage compartments just to get the bottom of the engine (ballasts??). What do you guys do?
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    There will be bulkhead panels you'll need to remove. No way around it. That's still true of even the 2019 Super Air boats. How they're mounted changed over the years so you'll have to dig into it and figure out what's holding them in. Once you get them in and out a time or two it gets pretty easy.
    -Charles
    • dominator
      • Sep 2018
      • 36
      • Burlingame, CA
      -Charles
      hmmm, I am still not sure what bulkhead panels I have to remove. I already removed the once that divide engine and storage compartment. Do I have to remove the bottom of the storage compartments? There is another set of bulkheads dividing whatever is under the storage and the engine. If I am not mistaken there is ballast under storage, so I would have to remove ballast too
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        The ballast tanks most likely do NOT need to come out in order to access the raw water pump, oil filter and fuel filter. There will be more panels that are screwed or bolted in that have to be removed to get access.
        -Charles
        • xlwater01
          • May 2013
          • 20
          • Milwaukee
          • 02 SANTE
          I have a 2002 super air team edition. Mine has the wedge ballast tanks in the rear compartment on either side of the engine so it is slightly different. However the truth is you just have to get creative with accessing certain maintenance items on the engine. Some of them are a pain to get to thatโ€™s for sure especially the GT-40 that, for example, does not have a remote oil filter.
          Get some lights in the engine bay and lay sideways on the ballast tanks, you should be able to get to everything you need. Or laying on top of the engine and reaching into the back is another option. Take your time and all maintenance items are doable on a vdrive, certainly not as easy as a ski nautique though!
