2013 zr409
  • d_nodixon
    • Sep 2008
    • 475
    • Hammond, LA
    • 2013 SAN 230
    2013 zr409
    Slight tapping noise...take a listen and let me know if this normal
    Sent from my Pixel 2 using Tapatalk
    2013 SAN 230
    2006 SSN 210 (SOLD)
  • d_nodixon
    • Sep 2008
    • 475
    • Hammond, LA
    • 2013 SAN 230
    https://photos.app.goo.gl/18MyvaDfRYirniHR9
    2013 SAN 230
    2006 SSN 210 (SOLD)
    • Infinity
      • Sep 2017
      • 730
      • Lake Norman - Denver, NC
      • 2014 SV244 w/ ZR409
      Is boat in gear or just sitting and idling? May be worth buying a mechanic stethoscope to isolate where the noise is coming from. I actually bought one last week from Amazon since I am going with a friend this weekend to look at a 2012 boat that has a ZR409 in it, figured its a good thing to have regardless.
      Is it possible the noise is coming from the butterfly in the carb? If you use the neutral lockout and rev engine up a bit to like 1000rpm....is noise still there?
      Its a short video, but the noise does not sound consistent (like associated with engine revolution). Sounded like a double tap the 1st time and then a triple tap the 2nd time.
      • d_nodixon
        • Sep 2008
        • 475
        • Hammond, LA
        • 2013 SAN 230
        Correct, the taps repeat that same pattern over and over. No carb though. It is just idleing and seems to go away at higher rpms. Want to say it there from 700 rpm up to about 1100. Goes away or can no longer hear it. Can feel and hear a slight hesitation that conicides with each tap. No issues performance wise.
        Best I can tell the sound is coming from the port side towards the stern.
        2013 SAN 230
        2006 SSN 210 (SOLD)
        • d_nodixon
          • Sep 2008
          • 475
          • Hammond, LA
          • 2013 SAN 230
          Alright, figured this one out. Fired her up to get ready for spring and noticed the same sound. Slightly louder and more of a hesitation/miss. Leaned in and noticed a spark/arc flash coming from inside the plug wire boot. Pulled the plug and there you have it, cracked porcelain insulation
          2013 SAN 230
          2006 SSN 210 (SOLD)
          • MrJake
            • Mar 2004
            • 73
            • Bellingham, WA
            • 2013 200V Team Edition 1979 Ski Nautique
            Good catch. I'll have to keep this in the back of my mind for when it happens to me.
            • Infinity
              • Sep 2017
              • 730
              Good catch! They recommend spark plug replacement at approx 4-5yrs or 500hrs, you can tell from the overspray that those are the factory plugs. When I replaced mine last winter, I used a small amount of dielectric grease on a cuetip to carefully go around the inside of the boot. You wanna be careful to not touch the plug tip when you re-install the boot, but its supposed to keep the plug from any arcing.
              FYI... even tho the price looked good on Amazon, there were a lot of reviews that said the plugs where knock-off and how to tell. I ended up getting mine at Advance Auto, they were running a rebate special then and I still got a good deal. My 2014 ZR409 purrs, such a nice quiet engine
              • d_nodixon
                • Sep 2008
                • 475
                • Hammond, LA
                • 2013 SAN 230
                Yep, was on my to do list anyway. Think I'm a little over 300 hrs.
                2013 SAN 230
                2006 SSN 210 (SOLD)
