So I just got a 2005 Air 206. Went out for the maiden voyage today and forgot to close the trick tank valve in the engine compartment. After riding around for a few I noticed the tank gauge read full. I closed the valve and pressed and held the belly tank button. Light began to flash but no water was pumped out. Tried cycling the button a few times but nothing worked. Once back on the trailer and in my driveway water was slowing coming out of the through hull fitting for the tank. I opened the valve and water def came out faster for a few sec but then went back to the slow dribble. I thinking the pump to empty the tank is bad. Is there a manual way to dump the tank. Do I need to find a steep him to drive down with the truck and stop and let it drain out? Will that even work? The valve was closed and the selector switch under the console was closed as well. No idea why it wouldnt pump out other than the pump being dead. Thanks for any input.
The 2005 206 should have two tanks in the back. Are they both full?
You should be able to hear the pump(s) running, if they are in fact working. Especially if you stick your head in the rear compartment and listen. If they are not running, check the breaker under the dash.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
There is only (1) tank on my 206. There are (3) ballast buttons on my keypad however, have you tried each one? Want to say on mine is connected to the furthest left ballast button, belly tank IIRC.
One push steady light = fill, push and hold blinking light = empty
