409 belt alignment issue
  • HydroWAL
    • Jun 2019
    • 5
    • 2013 G23
    Long story short. Annual service was done. About 7 hours after the idler pulley and belt went. I have replaced them but the belt is riding up on the shoulder out the alternator pulley. I have aligned the belt several times but as soon as the motor turns over it jumps back up on the shoulder. All the pulleys are tight, the belt is aligned everywhere else. Could something have gotten out of line when the impeller was changed. Any help or suggestions would be appreciated.
    Thanks Bill
  • Infinity
    • Sep 2017
    • 730
    • Lake Norman - Denver, NC
    • 2014 SV244 w/ ZR409
    Was it staying aligned right after idler pulley was replaced and didnt start getting on shoulder till after an impeller change? Since impeller is only held on with those 3 screws, if not properly installed you would think the impeller housing would be leaking water like crazy and not wanting to prime. Its possible the alterator pulley or one of the others is out of whack and is causing the issue, if you remove the belt by hand and turn all the pulleys, do any of them not feel right...I dont think the alternator itself is adjustable, but perhaps the bearings on that pulley are worn out?
    • scottb7
      • Aug 2011
      • 2198
      • Carson City, Nevada
      Maybe this would help. Not too spendy.
      https://www.royalsupply.com/store/pc...QaAvFNEALw_wcB
      https://www.youtube.com/watch?v=s9Jd7i_sIwk
      https://www.ebay.com/itm/Gates-Racin...AAAOSw5SlcsWoH
      Or maybe even figure out how to secure small laser pointer with similar method for "free99"...
      • HydroWAL
        • Jun 2019
        • 5
        • 2013 G23
        Thanks for the replies. After looking at it again this morning, the only thing I can find out of the ordinary is a little slop in the tensioner pulley. Maybe it is throwing the belt at the idler pulley at an angle that is slightly off. I will try replacing it and see how it goes. Thanks again for your help.
        • HydroWAL
          • Jun 2019
          • 5
          • 2013 G23
          Changed the tensioner pulley, the belt is still riding up on the alternator pulley. I guess I'll change out the tensioner assembly next.
